Combatpigg's 1903 wright flyer
#51
I did read recently read about where dihedral was used in some 1800's glider tests.
#52
Overdrive is a mechanical disadvantage [from the engine's perspective], so even with a perfect drive system with zero losses, it's quite a "cross to bear" for an engine that is being maxxed out.
Bonneville Salt Flat racers blow engines up often, even though they gradually accelerate the engines up to fairly common rpms [for a race prepped engine].
#53
Yes understand very true.
Objectives:
- run engine at same rpm already established
- gear up to increase prop rpm
- bench test props
- design plane to suit selected props, rpm, dia. and pitch.
- like Wilbur and Orville avoid ridicule / hide project till objectives achieved
Could use one of my BB .05 RC car engines if I decided to source a small belt and wheels.
Objectives:
- bench test props
#57
I like the simplicity of the design one could make a actual Ultra lite for low flying over good ground perhaps 30hp should be enough. All aluminum open framed flat square stock tig welded fuselage with a 3 gal tank and a 1/3gal hopper gottah land tank. Rip stop nylon covered aluminum framed wings.
#60
Yes, the dual exhaust would be a nice project to practice making sleeves.
The lathe belt arrived today, so I was able to whittle out the new pulleys.
The engine starts and runs easy enough now...well enough to consider the Power Plant finished enough to move on to building the rudder and setting up the controls.
I think there is ample thrust to fly this thing. I'm not sure if loops and rolls are in the cards, I expect just keeping it from crashing will be a big enough undertaking. https://youtu.be/q0WgeqkeuJM
#61
Now if you could just pipe the exhaust into a Y fitting and spit half of it into the top of each of those slave driven crankcases, you'd have yerself a lube system.
Crazy project, I hope it flies. It's too funny not to.
#62
I tried a scratch canard for the first Design Contest [IIRC] and it was somewhat controllable but not a very good flyer. It was stable enough to fly more or less level, but the close coupled canard didn't have much pitch authority until you cranked in a bunch of throw and by then it acted like a speed brake. After playing with various CGs, control throws and canard areas I threw in the towel and went with a fixed canard / elevon type plane that flew OK.
#64
My pleasure..!
Thanks for encouraging me to try an O-ring drive.
Before this design project was announced I bought a small stainless coffee mug / thermos that came complete with a domed lid. The lid seals with a pair of large O-rings [that I have never used] and they ended up being what I designed this contraption around. A whole bunch of spare O rings just came in, but I'm still using the original pair.
#65
ON, CANADA
Hi CP,
Wonderful Project!
I'd drill 1/32nd holes in the top of the outer cases, to drip 3-1 oil in,
The Cox Heatsink worked great in my car projects. (heavy cast al.)
Could be 'swisscheesed' for flight...
I imagine Orville saying, to Wilbur,
"Are You Sure ?"
Great Project CP,
Cheers,
Dave'crosscheck'Fallowfield
Wonderful Project!
"Are You Sure ?"
Great Project CP,
Cheers,
#69
I first started using 8in dia 4mm O rings as starter belts for my .049 thru .074 nitro boats. Then used them as belt drives with electric projects for quite indoor non geared electric brushed motors. Later I use them for retainers on prop saver hubs for my brushless motors. And most recently a 6in dia. 3mm for starting my TD .020 mono hull Cracker boat.
#71
Yes most standard size elect starters has a groove in the cone for belt starting boat engines. There is specialized tooth belts for starting larger engines, at the time O rings was a solution for the small engines with a little searching I would imagine there is a nice 3mm wide tooth belt around 6in out there on the web.
#72
I've rigged the ailerons and built the rudder. I cheated on the rudder design, just to avoid making a naturally tail heavy design even worse. At this stage, I just want it to resemble a Wright Flyer on camera and be airworthy.
Once the servos are installed, there isn't much else to do except march on down to the hay field with a box full of repair supplies and see if it will fly.
The Smithsonian failed in their attempt if you recall. I never understood why they would go to so much expense to recreate the original plane and then impose a phony deadline to either get it airborne or else ship it to the museum.
#73
http://sdp-si.com/ss/pdf/80502020.pdf
http://www.sdp-si.com/web/html/newprd1mmbelts.htm
1/8" wide kevlar reinforced timing belts, and plastic pulleys.
#74
