Sig Hummer
The Toki is real heavy. Get the brodak. If you use the toki, you will have to add lots of tail weight, bringing the overall weight of the model high and raising the wing loading. It will no fly well.
Move the fire wall back and get the Toki .05 or the Fuji same engine really just renamed.
Smooth running with great power and clean running makes very little goo other than out the exhaust.
Here is the .05 running on the DART. You can swap the heavy carb out for a vintage OS 10 as shown
all up weight of the engine is 76.4g. A sportswerk header pipe fits great for exhaust diversion.
Sportwerks Header Pipe :
https://shop.stormerhobbies.com/product-p/SWK4122.htm
https://www.youtube.com/watch?v=Id3Uun8gG5s here it is with a tuned pipe:
https://www.youtube.com/watch?v=7IaQ4o_qXZ8
76.4g with prop and spinner.
The sportwerk header adds another 3.8g as I recall.
Mecoa sells a muffler for it and it sounds good if used
you will need to move the firewall back a bit more.
Here is the muffler sound with another .05 car engine
sounds the same for all these .05 care engine brands.
Fuji .05, Toki .05, Sportwerk .05, Picco .05, CY .06
https://www.youtube.com/watch?v=AgFSqnMf9dk
My Feedback: (85)
Norvel .061RC is the one I would choose. Available new here:
Airplane engines
Or pick a used one up on the auction sites.
Airplane engines
Not a whole lot posted about the Sig Hummer, but it is a nice little plane, quick building, and easy to follow instructions. Cannot remark on flying as mine has been built for about 15 years already and still has a few little things to get airborne.
I built a Sig Hummer from a kit. I power it with a Gilbert .07 engine. It works absolutely terrific! If I ever understand the machinations of putting the picture on the message, I will do that, also. By the way, the little plane flies absolutely perfect, with no dihedral and the ailerons. Built exactly like the kit instructed.
Picture of a Hummer
This is my HUMMER, built exactly to the kit's dimensions and I used the kit wood. I did install a brutha for the pilot of the Hummer.
Last edited by GUS THE I.A.; 09-04-2017 at 10:48 PM. Reason: Cannot seem to get a picture on here
Have you gone to the "Go Advanced" button? Then follow through after that. We like pictures. And welcome to the forum. I got one of those Gilbert engines, but never thought of using it for RC, as there is no throttle. Picked up an .11 Gilbert too. They look so cool.
