Help me: Me109 HOB
Help me: Me109 HOB
Hi guys
I have had a small problem with the building: The two semywing are not perfecly aligned: there are a little (less then 2)decrees of different on alignement. what I can do? I glued the semywing together with epoxy
Alex
Alex
My Feedback: (7)
wing
cut them back apart using a razor( along glue joint) saw then sand there ends with a tee block, using a flat table as a guide, there shouldn't be a problem with the 1/4 inch of wing loss
