Go Back  RCU Forums > RC Airplanes > "1/2 A" & "1/8 A" airplanes
Reload this Page >
'Master of Insanity' build
"1/2 A" & "1/8 A" airplanes These are the small ones...more popular now than ever.
Old 05-12-2006, 03:31 PM
indoorff
indoorff's Avatar
Default 'Master of Insanity' build
Hey everyone
I have finally gotten around to starting a project for the GZ049 that I have had for a while, a model designed strictly for top speed, dubbed "Master of Insanity" (after the Black Sabbath song). Figured it would be a fitting name to a plane designed for insane (hopefully) speeds.
I will post pictures in this thread as the building progresses. So far, I have been carving fuselage plug, which will eventually be moulded in carbon fiber. I started with the hideous 2x4 in the picture below, and carved it into the plug you see. I still have to sand the plug to perfection, and give it many coats of varnish yet, but the overall shape is correct now.
EDIT : sorry, I have no idea why the pictures have organized themselves in a manner that makes this post incredibly wide!
Cheers
Chris
ID:	460379   Click image for larger version
ID:	460380   Click image for larger version
ID:	460381   Click image for larger version
Old 05-12-2006, 04:12 PM
flybug
flybug's Avatar
Default RE: 'Master of Insanity' build
Wow, I really want to see the final product; I'm sure it will look better thatn that 2x4
Old 05-12-2006, 05:11 PM
Tim Wiltse-RCU
Tim Wiltse-RCU's Avatar
Chris,
Nice work for sure! My hands hurt just looking at all that sanding!
LAter,
Tim
Old 05-12-2006, 05:57 PM
combatpigg
combatpigg's Avatar
Looks gorgeous, Chris! [8D] I see your clever hatch line, nice to have that detail figured out in advance. Keep up the good work!!!
Old 05-12-2006, 06:35 PM
indoorff
indoorff's Avatar
Thanks for the compliments guys.
Flybug - it will be a long process, probably won't be finished for quite some time. And you are right, it cant look <much> worse than that 2x4!
Tim - I managed to carve and file a lot of it, after hogging it down with a rasp. Still a lot of sanding though
CP - Yup, thats a hatch line. The plug is two halves, plus a hatch. The wood glued together with brown paper sandwiched in between. When it comes time to break the plug apart, you simply wedge something in between the layers, and it pops apart with very little effort. It is something my uncle showed me, he makes many patterns for sand casting this way.
Old 05-12-2006, 07:06 PM
BMatthews
BMatthews's Avatar
... I think I see a few woodworms living in the raw piece......
Excellent thread start! And nicely done on the plug!
It seems a bit short though......
And like you I have no idea what the server is doing to the pictures.....
Old 05-12-2006, 08:15 PM
indoorff
indoorff's Avatar
ORIGINAL: BMatthews
You think so? It is ~19" front to back. My wing chord will not be quite as large as some, I am going for slightly higher aspect ratio, so I don't think it will end up looking too short. It better not anyways, the last think I want is a twitchy elevator
Chris
Old 05-12-2006, 08:36 PM
KidEpoxy
KidEpoxy's Avatar
I think I saw a board down in the creek for 3 years that looked better than that Starting Point 2x4 you got.
I'd say you deserve a medal just for getting a nice plug from that ugly board. Seriously.... that board needs to be euthanized.... I wouldn't use it for a chockblock.
You gonna have a horizontal seperator to keep the pipe heat out of the rest of the plane?
Old 05-12-2006, 10:10 PM
indoorff
indoorff's Avatar
ORIGINAL: KidEpoxy
Just goes to show the quality of materials they are using at the building site accross the street
ORIGINAL: KidEpoxy
I was going to do something with reflective aluminum tape on the pipe side. Is that generally considered a good idea?
Old 05-12-2006, 11:09 PM
combatpigg
combatpigg's Avatar
All I use to seperate the pipe tunnel from the rest of the plane is file folder paper that is covered with 4 oz cloth, then saturated with medium CA. I use a light mist of 3M77 on the cloth so it will stay put while it gets molded to the paper form. A piece of 1/16th balsa would make as good an insulator / form for the cloth as anything, too. The heat isn't a big deal and the space available to do much about it isn't there, anyway.
Old 05-14-2006, 06:15 AM
microengine
Looks great. I wonder if it would make a decent second plane
