Go Back  RCU Forums > RC Airplanes > "1/2 A" & "1/8 A" airplanes
Reload this Page >
Who else has built a 1/2A shrike?
"1/2 A" & "1/8 A" airplanes These are the small ones...more popular now than ever.
Old 10-15-2006, 05:17 PM
flyinrog
Default Who else has built a 1/2A shrike?
No hardware,,I'm just too lazy to build a kit..I ordered the dubro hardware to make the aileron control wire and they are both too short! so I am gonna go with a servo in each wing..BSarge said when he was working on the Rivets he felt like Paul Bunyan trying to put stuff inside it,this thing is waaay worse, it is built tough after you start gluing things together...I know I will end up modifying it some too...sanding?! who sands anymore..its barbaric!!...sure hope it flys ok cause I gotta build another one for the cook.....oh well just a small rant ...Rog
Old 10-15-2006, 05:22 PM
BSARGE
Default RE: Who else has built a 1/2A shrike?
ORIGINAL: flyinrog
The shrike is worse![:-] I guess I need to go to the hospital and "borrow" some micro surgical instruments[X(]
Rog- I think I am going to build the shrike before the ace ultimate...this 1/2a thing is growing on me...
Old 10-15-2006, 05:30 PM
Sneasle
imc onsidering the .10 sized one. Is that the same one ya'll are working on?
Old 10-15-2006, 05:41 PM
flyinrog
No this is for either 1/2a or speed 400 motor...its shown built with an .061, thats what I'm going with..Rog
Old 10-15-2006, 06:23 PM
SquirlNutZipper
My Feedback: (9)
SquirlNutZipper's Avatar
ORIGINAL: Sneasle
Hey Sneasle. I still have a box of nitro gear for ya.
Alex
Old 10-15-2006, 06:24 PM
peter_gibbons
I've built 2, i didnt have any problems building either one..... micro gear... norvel 074.... piece of cake.. just be prepared for the roll rate hahhahahh
Old 10-15-2006, 07:02 PM
BSARGE
Ok, I couldn't wait anymore, So I started it tonight...no time like the present!
Old 10-15-2006, 07:39 PM
rainedave
rainedave's Avatar
rog, you should be able to finish it tonight... seeing as you left your phone off the hook and won't be disturbed by any calls.[X(]
Keep us posted with lots of photos of the build.
Old 10-15-2006, 08:03 PM
flyinrog
Maybe Bill can help, I don't own a camera....I rely on you guys for that stuff...Rog
Old 10-15-2006, 08:42 PM
rainedave
rainedave's Avatar
Doh! I thought that was your photo, rog. I got confused with two people building the same kit in the same thread.
Old 10-16-2006, 07:11 AM
BANJOAIRPLANE
I guess the journey starts with the first step!Way to go Bill,you are making me want to try to build again.Maybe I can get Rog to bring the other kit to my lair and let me try again.[X(]
Old 10-16-2006, 07:33 AM
Schu
Rog,
I guess I have built 5 or so incuding the scaled down .20 size Shrike I built ( you think the 1/2A is tough to fit servos ). I may have some photo's of the radio gear if you need to see how I fit them. The first build was tough as it is way different than a normal build ( hanging one side over the end of a table etc ), but the rest went w/o a problem. On the nose area just us some trangle stock inside and then use your power sander and sand it down to meet your spinner or alum. spinner nut. This saves alot of hand sanding.
Dale
Old 10-16-2006, 09:05 AM
dieFluggeister
Hey guys I gotta Shrike kit sitting in the closet. Mind if I build along with you guys?
I think however that I might be using the big bad "E" word on this one. Is that legal?
Old 10-16-2006, 09:19 AM
ptulmer
ptulmer's Avatar
dF, can you tolerate the public humiliation cast upon those "e-fliers"?
Old 10-16-2006, 09:30 AM
propbuster
propbuster's Avatar
ORIGINAL: ptulmer
PT, ya know, I'm beginning to think charging a battery and flipping a switch is a whole lot easier than dealing with a finicky Cox engine!
Old 10-16-2006, 09:42 AM
dieFluggeister
Humiliation? Naw, I'm used to it.
Old 10-16-2006, 09:47 AM
KidEpoxy
KidEpoxy's Avatar
wasnt it Jeff Foxworthy that said
If you clean your closet and discover a Plane Kit, you might be a 1/2A'er
Old 10-16-2006, 12:13 PM
ptulmer
ptulmer's Avatar
Prop, if you have fuel, air and heat, the Cox engine is about the same as flipping a switch. Hey, maybe you can get Glade to make a "burnt castor" scented oil candle....
dF, you're married too, huh?[sm=lol.gif]
Old 10-16-2006, 12:40 PM
Schu
Like a switch to a flourescent light that has a defective ballast! Tries to work- wants to work- runs a little, maybe- but never comes on. Put in that Norvel ballast and all works good.
Old 10-16-2006, 01:12 PM
hfenn
ORIGINAL: BSARGE
I see you left the phone off the hook so you won't be interrupted.
Old 10-16-2006, 01:16 PM
dieFluggeister
I have seen a mod using a CF rod for the main spar and removable v-stab fins. Any other mods you guys know of?
Old 10-16-2006, 01:19 PM
propbuster
propbuster's Avatar
ORIGINAL: Schu
Yup, Exactly! I replaced the carb body and put a new KK fine thread needle valve assembly along with a nice venturi on one of my TD's a couple of days ago. Put it on my 182 Skylane and test ran an 1oz tank worth of fuel through it and it ran just like clockwork. Got it to the field yesterday and it wouldn't start/run for $**T! I got one flight out of my old motor glider with another TD on it after messing around for 1/2 an hour getting that one to run. After yesterday, I'm ready to trade all my Cox stuff for one Norvel. Maybe I just don't have the patience I had as a kid when Cox was king.
Old 10-16-2006, 03:32 PM
ptulmer
ptulmer's Avatar
Prop, what kind of Norvel?
Old 10-16-2006, 07:38 PM
vicman
My Feedback: (10)
vicman's Avatar
Sarge, I can't see how you complain about how much room is in the Rivets[X(]. Are you guys gonna make me build a shrike now?[sm=50_50.gif]
DF, fear not you are not alone as the Mean Grean Rivets is now a lekky thanks to un-named vandals(gotta get a lock on that door). I hope to get a flight in soon but the W word is in the way at the moment.
Old 10-16-2006, 08:15 PM
SquirlNutZipper
My Feedback: (9)
Once you've got the first one out of the way the second, third etc can be built in a Sunday morning. They're quick building little birds, even quicker if you build electric.
Heck now I'm getting the itch to slap another one together.
Jeez thanks a lot guys
