Go Back  RCU Forums > RC Airplanes > "1/2 A" & "1/8 A" airplanes
Reload this Page >
Black Widow enough power for a simple series?
"1/2 A" & "1/8 A" airplanes These are the small ones...more popular now than ever.
Old 12-09-2006, 09:08 PM
chad500_0
Default Black Widow enough power for a simple series?
All,
My Norvell .061 RC is dead and so is my Simple Series AT-6. I have a simple series P-51 and ME 109 and I have two .049 Black Widows sitting in a box. Are the Black Widows enough power to fly these planes? I felt that the Norvell .061 was more than enough power once the plane was up, but will I be able to hand launch and climb with a .049 as my power plant? If I can, what prop should I use. These will be my winter building projects and I am not looking for a rocket.
thanks,
chad
Old 12-09-2006, 09:46 PM
flyinrog
Default RE: Black Widow enough power for a simple series?
I'm pretty sure Propbuster powered his ME-109 with a blackwidow...I doubt it will be a "rocket" so it should power you up okay...did the AT-6 go in so hard that the Norvel is dead?..Rog
Old 12-09-2006, 09:58 PM
propbuster
propbuster's Avatar
Hey Chad, I used a Shure Start production engine (same as a Black Widow?) in the ME 109 and it was a little underpowered in my opinion. I guess it flew okay but required a hefty toss on takeoff. I changed it out for the TD.051 that came out of my destroyed Cessna Skyhawk and it flew much better on the one flight I got in before the engine started acting up on me[:@] I tried to build it light and didn't cover it, just a light coat of acrylic paint and polyurathane for fuel proofing.
ID:	574472   Click image for larger version
Old 12-09-2006, 10:00 PM
digital_trucker
digital_trucker's Avatar
A Black Widow is likely more powerful than a Sure Start, though.
Old 12-10-2006, 09:28 AM
chad500_0
ORIGINAL: flyinrog
Rog,
The Carb from the Norvel was destroyed. I took apart the rest of the engine and cleaned it. I have the engine packed in a box somewhere and I can not seem to find it at the moment. I would like the ME 109 and the P-51 to be my fun planes.
chad
Old 12-10-2006, 09:48 AM
digital_trucker
Chad, if you ever run across your Norvel again, keep in mind that the carb from an AP .061 will probably fit it....I think.
Old 12-11-2006, 04:21 PM
ptulmer
ptulmer's Avatar
I believe the AP carb is different no matter which version Norvel you have. If you can post a pic of the AP carb, I can look at my older Norvels when I get home.
Old 12-11-2006, 09:00 PM
combatpigg
combatpigg's Avatar
Some BWs absolutely scream, some are duds. They usually run the range of 14-17,000 rpm with a 6x3 prop, out of the box. If yours' can turn a 6x3 at 16,000 rpm, then there should be enough oomph to fly care free. Make sure your launches are thrown level and with a little bit of "mustard" on them.
Old 12-12-2006, 12:31 AM
digital_trucker
ptulmer: I know that the body of the AP carb is different, but what about the bit that actually goes into the crankcase?
Old 12-12-2006, 08:17 AM
Andrew
Every NORVEL I've seen has an oblong base on the carb -- I believe all AP's are round.
Old 12-12-2006, 01:04 PM
simark
My Feedback: (12)
simark's Avatar
ORIGINAL: combatpigg
... Make sure your launches are thrown level and with a little bit of "mustard" on them.
Uhmmm.. ah... could you let me know what this "mustard" bit is all about?
Old 12-12-2006, 01:42 PM
SGC
simark,
mustard = hot = fast , that is launch it with a good bit of airspeed , so the engine has a chance to accelerate the model into a climb.
Stewart
Old 12-12-2006, 02:29 PM
simark
My Feedback: (12)
simark's Avatar
SGC
OK thanks. For a moment there, I thought you ½A guys were losing it.
BTW, SGC it must have been around 5:00 am when you replied. Now I KNOW you've lost it!
Old 12-12-2006, 04:42 PM
chad500_0
Shoot, I just spent six hours calculating the different drag ratio's between Dijon and yellow mustard to see which one would work best for hand launching.
Old 12-12-2006, 07:19 PM
nekked_man_2000
If I can post it, this one flew fine with a cox "product", or "sure start", engine before we dorked it in with a dead battery. Really looked slow, but would loop from level flight, a black widow is usually a far better engine than the "product" engine. Would have made a good park flyer with a muffler as slow as it was, but fun to fly.
It's really not that bright green, something about the sunlight and the digital camera made it look that way.
ID:	576040   Click image for larger version
Copyright © 2021 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
