Go Back  RCU Forums > RC Airplanes > "1/2 A" & "1/8 A" airplanes
Reload this Page >
.o49 engines by cox
"1/2 A" & "1/8 A" airplanes These are the small ones...more popular now than ever.
.o49 engines by cox
Old 06-25-2008, 09:02 AM
  #51
jessiej
Default RE: .o49 engines by cox
ORIGINAL: Bugzidor
The prop. is a vintage 'SCAMPER', I guess and I hope, I should have a video clip of this carb. available, soon.
I would recommend saving that prop as a collectable. I fired up an engine with one a couple of years ago and the lovely clear prop shattered after a few seconds of running.
jess
Old 06-27-2008, 09:41 AM
  #52
Yuu
I put the AP carb on the SureStart and it stuck out 5/8" beyond the rear of the grey plastic plate. How did you get the carb in there 'so short'? I used the plastic 'tube' the NVA goes in, covered that with a black piece of automotive rubber hose, right over the NVA hole, and plugged the carb into the black rubber. Then I shortened the black rubber until the carb hit the grey plastic tube near where the NVA goes through. No zip ties or hose clamps; just tight rubber hose. But the carb is still 5/8" out behind the engine mount screw holes. I built a test stand to run it. It can be done with a long motor mount stand-off... longer than the SS stand-off for the stock engine. I ran four 3/4 oz. tanks of fuel through it, and it throttles up and down pretty good, IMO. I need to remount it and get some tach readings.
I took it off so I could clean and run an engine for a kid from the 4H group here. Got two of his engines started and he was thrilled. Then I let him fly the CL 'Yellow Peril".... which made 1/2 a lap and the 'landing' busted the right wing into 15 pieces!! But it doesn't count as a "CRASH" because he didn't break the prop! ha ha
Old 06-30-2008, 04:47 AM
  #53
Bugzidor
I make the carb. body from a small piece of aluminum bar stock, so that, it can fit inside the engine plastic back plate and cut the plastic tube that the NVA goes in then press fit the new carb.(see picture), simple, isn't it? I also link to the carb. testing video clip.
http://www.rcuvideos.com/item/D125TSC8FFZB4YS6/received
Old 06-30-2008, 05:15 AM
  #54
topspeed
topspeed's Avatar
Awesome job...I just ordered a used 0.049 from a friend at 12,5 euros ( incl. mail ). There is none in stores here in Finland. I have 2 older 0.049s and one 0.02.
I have also an older Stels 0,049..they are outa business.
Pic below of it.
Old 06-30-2008, 11:53 AM
  #55
jetset1968
ORIGINAL: Bugzidor
This is my latest version carb. design for SS, which has more compact and relaible throttle responsive.
Any chance you could do a pictorial or video on how you retrofitted that throttle?????
Please !
Old 07-07-2008, 09:38 PM
  #56
Bugzidor
I'm sorry that, I do not have the pictures, how to retrofit, but, I have a couple drawing. Hopefully that, you could get some idea from them.
Old 07-08-2008, 05:42 AM
  #57
small_rcer
That design is clever!. The needle valve assembly has a venturi or carb throat body in the area of the fuel opening. The whole assembly including the needle valve rotates. Very trick!
I feel that, if Cox had thought of that, all our Cox motors would have been throttled a long time ago.
Congratulations on a very elegant design.
Jim H
Old 10-15-2009, 11:02 PM
  #58
Bugzidor
This is a Cox SS carb. that, available in Thailand, right now.
Old 10-16-2009, 02:58 AM
  #59
build light
build light's Avatar
This will surely get someones attention! Be prepared to tell how we can get these here! I feel sure this will attract someone.
Robert
Old 10-16-2009, 06:03 AM
  #60
Tee Bee
I'm attracted.
Old 10-16-2009, 06:17 PM
  #61
gene6029
gene6029's Avatar
Im in......Gene
Old 10-16-2009, 11:43 PM
  #62
Bugzidor
ORIGINAL: build light
Robert
I’m living in Bangkok, Thailand. Actually, I do sell Cox .049 SS engine locally and offer a carb., completely installation, as an optional to customer, who need it with us$ 7.50 on top of the engine cost (us$13.50 for Die Cast.), because, I have to use the engine’s fuel spray bar and needle valve to install at the carb.
If, you prefer to get one, you can, either purchase a complete set of assembled engine with carb. at us$ 21 (~us$8 for registered mail 14-21d., read time ) or just only an assembled Throttle with engine back plate, ready to install on your engine by replace the existing back plate, directly (need NV. and Reed valve assy’ from your existing engine), it will cost ~ us$9 and us$4 for registered mail
Right now, I have 3 complete sets of engine with carb., ready to ship, if you would like.
I prefer paypal, payment to my accnt. at ‘divaveja@hotmail.com’
Please email me, if, you would like to have more detail info. Thanks.
Joe
Old 11-17-2009, 11:37 PM
  #63
Bugzidor
ORIGINAL: Bugzidor
Trying to adapt SS carb. to TD .051, but, have not yet tested for the max. rpm. compare to the original venturi. Will be doing next.
ID:	1316280   Click image for larger version
ID:	1316281   Click image for larger version
ID:	1316282   Click image for larger version
Old 11-18-2009, 07:11 AM
  #64
old git
I eMailed Joe a request for a Die Cast .049 with carb'.
It arrived quickly and looks to be just what I required. It came with clear instructions on tuning and running.
I haven't been able to get around to testing it yet, I have mobility problems and half the household equipment decided to go on the fritz.
Just to add to the problems we have had to have a total new central heating system. MY WIFE HAS FOUND MY MODEL ROOM.
ORIGINAL: Bugzidor
Robert
Joe
I can heartily recommend a motor from Bruce? Is that really your name?
Waco Brotherhood No. 14.
old git aka John L.
Old 11-21-2009, 05:31 PM
  #65
Red Baron Mike
My Feedback: (285)
Red Baron Mike's Avatar
They are available at www.coxengines.ca
Old 03-21-2010, 12:16 AM
  #66
DeviousDave
ORIGINAL: topspeed
Pic below of it.
Hold onto that engine! It is a rare one!
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service - Do Not Sell My Personal Information
Copyright © 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
