AP Wasp and Hornet
AB, CANADA
RE: AP Wasp and Hornet
I don't know if this will help or not but, mabe navigate their site and they may have your answer. Here it is. http://www.globalhobby.com/public/mfr/ap01.asp
NE
ORIGINAL: Mr Cox
Hmmm, never even occured to me that there could be return policy on these (don't think they could afford it), I see it more as a lottery...
I also have two .09 Hornets and I have two .061 Wasps, although I have only used one of the Wasp engines to date. We keep reading on these forums that some users have great success and others don't. Is it possible those who claim the engines are bad just don't like them and are not satisfied instead of the engines actually being poorly designed or built? I am very pleased with the running of both the Hornet and the Wasp, although I have run less than a quart of fuel through them so far.
I am very curious from those who have considerable running time on either engine if they have ever worn out one of these engines. I would like to know from those who have been flying these two engines how much actual flight time and/or fuel has been run through them
so we can get an idea of their long-term durability.
Any comments from long-time users of either engine?
AB, CANADA
ORIGINAL: Red Baron Mike
Another thing to note, One of my AP .09's have a bronze bushed rod and the other one has no bushing. This one will take more care in breaking in. I bought both at the same time , so I don't know which one is newer. I hope if I buy another one, that it has a bronze bushed rod.
Weight wise, these engines are "piggies" but they can perform to make up for it if you are patient.[8D]
I have 3 of the 0.061 and 1 of the 09's The 061's seem to take about 20 flights to break in. Mine have all run sort of rich and had a up and down run when new. You could hear the engine going rich then lean out a little. They would not hold a needle setting. Each flight the swing in settings would get smaller. Mine seem to run well on YS 20-20 fuel. They will not idle down until they are fully broken in. They run well for what you pay for them.
I would like to see a new 1/2A engine come out that had the power and ran like a big engine.
I just need to find the old flexible Cox props for these engines. They run well with that prop.
Dru.
Dru.
