Go Back  RCU Forums > RC Airplanes > "1/2 A" & "1/8 A" airplanes
Reload this Page >
Cox fuel tank extender
"1/2 A" & "1/8 A" airplanes These are the small ones...more popular now than ever.
Old 03-16-2010, 08:53 PM
jsesere
My Feedback: (38)
Default Cox fuel tank extender
I have a fuel tank extender for a Black Widow that is missing one of the four screws. I believe it was made by Kavan, but I'm not sure. The screw is the standard 2-56 Fillister head but is only threaded at one end. The screw measures 1 1/2" long. Does anyone know where I can get replacement screw?
It doesn't need to be completely threaded if that's all that's available. I have searched the internet without much luck so far.
Old 03-16-2010, 10:12 PM
Andrew
Default RE: Cox fuel tank extender
Here is a possible option if you can't locate a 1 1/2" screw.
Get a pack of 2-56 blind nuts and a piece of 2-56 threaded rod (or cut the threaded portion off a 2-56 screw). Since many of the threaded rods are rolled threads, a section of machine screw would probably be better. Run a screw into the blind nut to hold it and using a file or bench grinder, remove the flange leaving a short threaded barrel. You can get fillister head screws, just not in the length you need. Put a shorter screw thru the back plate, use the threaded barrel as a coupling nut and add enough theaded rod to make up the needed length.
You may or may not want to add a little thread locker to the coupling - it may dissolve in the high nitro. If you will give the coupling a light rap to get it slightly out of round, it will hold tighter. Not ideal, but I think workable.
andrew
Old 03-16-2010, 10:50 PM
Tee Bee
You might try RTL Fasteners. They've got all kinds of model hardware.
Old 03-16-2010, 11:10 PM
ChopperMike
I just checked on RTL and they don't have anything over 1" long. I too had a need a while back for some longer 2-56 and had to give up and use something else.
Mike
Old 03-16-2010, 11:14 PM
jsesere
My Feedback: (38)
I have been all over the internet and also had no luck. Somebody must have made these for Kavan at some point. Does anyone know if they are still in business?
Old 03-17-2010, 12:32 AM
build light
build light's Avatar
How about using a one inch threaded 2-56 threaded rod from a nyrod or one like it and about quarter to three eighths inch of inner nyrod tube to join to to a shorter length of fillister head bolt that wojuld be easier to find?
Robert
Old 03-17-2010, 12:57 AM
ffkiwi
You obviously didn't look very hard-Microfasteners has 1-1/2" 2-56 machine screws-though not in filister head. They have them in pan head and socket head though-I'd suggest socket head as it will probably fit without having to grind the head diameter down-and you can buy them in lots of 10. The pan heads are in 50's or 100s. See www.microfasteners.com
ChrisM
'ffkiwi'
Old 03-17-2010, 01:14 AM
Silvaire
My Feedback: (50)
Silvaire's Avatar
McMaster Carr also carries 2-56 X 1 1/2 machine screws:
http://www.mcmaster.com/#machine-screws/=6934ik
These are slotted round head stainess. You'd probably have to turn the heads down, but then they'd be pretty close in appearance to the original filister head screws. (You can chuck 'em in a Dremel and use a file if nothing more sophisticated is available.)
Edit: I just tried the link I posted and it just gets you to their machine screws in general. You'll have to drill down through the menu to find the 2-56 X 1 1/2 slotted round head stainess machine screws.
Old 03-17-2010, 04:56 PM
dckrsn
dckrsn's Avatar
ORIGINAL: ffkiwi
You obviously didn't look very hard-Microfasteners has 1-1/2'' 2-56 machine screws-though not in filister head. They have them in pan head and socket head though-I'd suggest socket head as it will probably fit without having to grind the head diameter down-and you can buy them in lots of 10. The pan heads are in 50's or 100s. See www.microfasteners.com
ChrisM
'ffkiwi'
I've used 2-56 socket head machine screws from MacMaster-Carr(both stainless and black oxide) on several Pee-Wee and Bee style backplates,
and they fit beautifly with no modifications.
I have a couple of the Kavan extenders, and the included screws are pretty soft. Maybe aluminum?
Regards,
Bob
Old 03-18-2010, 01:18 AM
ptulmer
ptulmer's Avatar
Maybe I got different screws than Bob did, but I had to chuck them up in the drill and grind a tidbit off the head to get them to seat properly. Got mine from McMaster-Carr. If you are gonna fly 1/2a much, go ahead and order some prop screws in various lengths, too.
Old 03-18-2010, 10:13 AM
fritzke
I have a Kavan tank extender as well, but the screws I got with it were not correct threads
to fit the Cox crankcase, so I never used it. Other than it ruining the tank, drilling a hole
in the stock tank shell and using an external one seems to be the way to go.
Dave
Old 03-18-2010, 01:51 PM
flyinrog
I have one, and if yours is like everyother one I've seen it wont matter, it'll leak anyway....Rog
Old 03-18-2010, 04:05 PM
fritzke
Plus the extra place the extension tube creates for the intake to leak air, another reason to just use an external tank.
Dave
http://www.rcuniverse.com/forum/m_44.../tm.htm#446499
Old 03-18-2010, 05:45 PM
jsesere
My Feedback: (38)
Thank you to everyone especially to Bob who is going to send me some screws to use.
You gentleman have been a great help.
Joe
Old 03-18-2010, 07:54 PM
lildiesel
lildiesel's Avatar
ORIGINAL: Silvaire
That move counts as state-of-art high tech on my work bench. [8D]
Old 03-21-2010, 10:26 PM
Frank Schwartz
The Kavan extensions used to be carried by Hobby Lobby many. many years ago. They worked great! The first ones were aluminum and did not leak. The later ones were/are plastic and do leak.... You might check with H/L and see if they still stock them...or you might check with Sig. Jim Martin, past owner of H/L son married Kavan's daughter (from Germany) and they live now in Montezuma Iowa and work with Sig....
Old 03-22-2010, 12:34 AM
build light
If anyone still has a copy of the 1974 Sig catalog they were in there as well! I remember those Sig Catalogs well. Oly cost three dollars then and came with a three dollar gift certificate good on any order!
Robert
Old 03-22-2010, 02:10 PM
Tee Bee
I also experimented with one of these tank extenders a couple of years ago on a Black Widow with frustrating results. Couldn't ever get the engine to run well for long. Seemed to have an air leak in the induction regardless of how careful I was to assemble it with good o-rings. Made some from fuel tubing but they didn't work well either. Ended up setting it back up with the stock tank and the good performance returned.
Copyright 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
