NORVEL engines and parts are back
CA
Norvel engines and parts now back in production. The exclusive US distributor's email is [email protected]
Here is a price list. Prices for Norvel engines 0.15, 0.25, and 0.40 will be posted later
<colgroup><col width="305" style="width: 229pt; mso-width-source: userset; mso-width-alt: 10837" /><col width="106" style="width: 79pt; mso-width-source: userset; mso-width-alt: 3754" /><col width="64" style="width: 48pt" /></colgroup>
Item | Part number | Price |
Norvel Big Mig 0.049 CL | $60.95 | |
Norvel Big Mig 0.049 RC | $63.95 | |
Norvel Big Mig 0.061CL | $69.95 | |
Norvel Big Mig 0.061 RC | $72.95 | |
Norvel Big Mig 0.074 RC | $84.95 | |
Norvel Big Mig 0.15 RC | $89.00 | |
Norvel Big Mig 0.25 RC | $95.00 | |
Norvel AX-40 RC BB Revlite | $109.00 | |
Crankcase 04-06 | 100108-01 | $22.99 |
Crankcase 07 | 100108-02 | $23.99 |
Crankcase 15 | 300002-03 | $24.99 |
Crankcase 25 | 400108 | $27.99 |
Crankcase 40 | 600002 | $29.00 |
Crankshaft 04 | 100110-01 | $18.95 |
Crankshaft 06 | 100110-03 | $18.95 |
Crankshaft 07 | 100256-01 | $19.95 |
Crankshaft 15 | 300110-03 | $20.95 |
Crankshaft 25 | 400110 | $22.95 |
Crankshaft 40 BB | 600008 | |
Cylider/Piston assembly Big Mig 04 | 100406 | $24.95 |
Cylider/Piston assembly Big Mig 06 | 100402 | $27.95 |
Cylider/Piston assembly AME 06 (limited stock) | 100401 | $37.95 |
Cylider/Piston assembly Big Mig 07 | 100407 | $29.95 |
Cylider/Piston assembly AME 15 | 301004 | $35.95 |
Cylider/Piston assembly AME 25 | 401004-01 | $37.95 |
Wristpin 04 | 100103 | $3.95 |
Wristpin 06 | 100103-03 | $3.95 |
Wristpin 07 | 110103 | $3.95 |
Connecting rod 04 | 100109-01 | $7.95 |
Connecting rod 06 | 100113 | $7.95 |
Connecting rod 07 | 110109 | $8.95 |
Head wrench 04-07 | 230131 | $3.95 |
Head wrench 15-40 | 230132 | $9.95 |
Glow plug 04-06 | 110138 | $7.95 |
Glow plug 07 | 110158 | $8.45 |
Standard glow plug | 301158-01 | $5.99 |
Head adaptor for std. glow plug 04-06 | 100148 | $4.29 |
Head adaptor for std. glow plug 07 | 300001 | $4.39 |
Head adaptor for std. glow plug 15 | 300207 | $4.95 |
Cover plate 04-06 | 100100 | $7.95 |
Cover plate with a pressure fitting 04-06 | 101005 | $12.95 |
Cover plate O-ring 04-06 | 300209 | $3.29 |
Cover plate 07 | 100255 | $8.29 |
Cover plate O-ring 07 | 100209 | $3.29 |
Spring starter | 102105 | $6.95 |
Cylinder head gasket 04 (2) | 100112 | $3.29 |
Cylinder head gasket 06 (2) | 100112-01 | $3.29 |
Cylinder head gasket 07 (2) | 100116 | $3.49 |
Cylinder head gasket 15 (2) | 300112 | $3.89 |
Glow head gasket 04-06 (3) | 100117 | $2.99 |
Glow head gasket 07 (3) | 101717 | $2.99 |
Needle valve screw 04-25 | 120114 | $8.95 |
Prop screw 04-06 | 100137 | $2.50 |
Prop screw 07 | 100337 | $2.50 |
Prop shaft 15 | 300324 | $2.99 |
Prop spinner 04-06 | 100102 | $4.95 |
Prop spinner 07 | 100302 | $4.95 |
Prop hub 04-06 | 100124 | $5.95 |
Prop hub 07 | 100124-01 | $5.95 |
Prop hub 15 | 300321 | $5.95 |
Drive gasket 04-06 | 100136 | $1.99 |
Drive gasket 07 | 100136-2 | $1.99 |
Drive gasket 15 | 300136 | $1.99 |
Venturi assembly 04-07 (without needle) | 101159-02 | $14.95 |
Carburetor assembly 04-07 (without needle) | 110159RC | $22.95 |
Venturi O-ring 04-07 | 100209 | $2.89 |
Throttle lever 04-15 | 100202 | $3.95 |
Throttle lever stop spring 04-07 | 100204 | $2.89 |
Throttle lever stop screw 04-07 | 100205 | $2.89 |
Venturi nut 07 | 100281 | $2.89 |
Venturi screw | 100291 | $2.89 |
Cylinder head screw 04-06 (qty 4) | 100127 | $4.39 |
Cylinder head screw 07 (qty 4) | 100325 | $4.49 |
Muffler 04-06 | 101003 | $15.95 |
Muffler pressure spring 04-06 | 110120 | $2.99 |
Muffler assembly 07 | 110157 | $19.95 |
Muffler assembly 15 | 300003 | $23.95 |
Muffler spring 15 | 300142 | $2.99 |
Muffler O-ring 15 | 300209-01 | $2.89 |
Head 04-06 | 110131 | $5.95 |
Head 07 | 120131 | $5.95 |
Diesel head (conversion to diesel) 04-06 | 400401 | $22.95 |
Wire net 04-07 | 100122 | $3.49 |
Fuel tank mount 04-06 (0.5 oz.) | 102100 | $14.95 |
Fuel tank mount 04-06 (1 oz.) | 102200 | $19.95 |
