Need help with AP Hornet .09
How do I get the shaft out? I am trying to change the bearings but the shaft wont budge. I have loosened the inner bearing by heating the engine, the front one wont move.
RE: Need help with AP Hornet .09
Get the thrust washer off and remove the taper collet. Tap on the crank shaft threaded end with a piece of wood.
Thans alot, it worked!
