TeeDee .090
Hello Guys,
I am also playing with a .090 at the moment. I was disassembling it and I destroyed the phenolic washer behind the prop hub. I couldn't find a replacement on the cox engines site. Where can I get a replacement washer from? Much TIA Rick |
http://www.ebay.com/itm/Cox-074-Quee...-/271959297577
Might be able to make the above phenolic thrust washers to work if not there are steel ones bellow. http://www.ebay.com/itm/Cox-09-Tee-D...8AAOSwgQ9V0NSo |
I ordered the metal one, it looks sintered. I'll give it a try and see how it works! I also ordered a rod resetting tool, I'm going to tune this one up and put it up against my .049. Thanks! Rick |
1 Attachment(s)
Sure here are the power charts the .09 is a bit more than twice the watts.
Good for a 2lb airplane. Better for a 14 to 24oz plane real rocket. http://www.rcuniverse.com/forum/atta...mentid=2162015 On a side note my TD .049 / SPI with exhuast throttle, exceeds the power chart: High compression head 1 shim. 4.1 x 4.1N / 30% nitro Static 24,790 rpm / 7.4oz thrust / .127hp / 94.74w / 96.2 mph Modern prop modified for performance helps to change old school info as I was only using 5% more nitro. + 15.74w Real good odds of getting over 20w increase with a .09 and modern performance props. |
| All times are GMT -8. The time now is 07:12 AM. |
