061 to electric
what setup do i need to replace the 061 nitro engine to electric power. i know nothing about electric power. motor controller and battery combo would be nice
Might be best to ask in the Electric section.
Try here. https://www.rcgroups.com/forums/show...ville-Arkansas
There are a bunch of diehards there that have done this and we still talk to them. |
This is the place to convert electrics to glow engine power! But both directions of conversion get talked about at times.
For reference a good TD .049 will peak at about 80 watts output, a Black Widow about 60 watts, Medallion .09 RC 120-ish, TD .09 165-ish. Rough numbers but it puts things in perspective. It is easy to stuff some more hp in there when converting. It's also beneficial to swing a bit more prop at lower rpm to cut down the prop noise if that is a consideration. |
