My New IC 12 Jet
1 Attachment(s)
My latest IC .12 Jet.....
Will test fly this weekend. IC Sc 12 Prop 8*6 or 7*4 Wing area 290 sq inches Weight a bit heavy at 28 ounces. Wing loading about 14 ounces, need to get that down to 10 to 12. But she looks good. I feel a tractor version coming on. ACR007 |
RE: My New IC 12 Jet
I built a sheet wing delta with the same color scheme in the mid '70, it was more than I could fly[:@] in those days, very fast roll. Yours really has a nice shape, a little Multiplex twin jet influence? Very cool!:D
Very nice! I suspect that there's more than one of the folks here that would like a set of plans if you're willing.
plans? who said plans.. ooohhh.. plans.. me want plans.....
looks great. tractor version woudl be interesting, but i think i like it this way better |
Looks Evil, Wicked, Mean and Nasty.....nice work!! [8D] Good luck with your flights.
ORIGINAL: acr007 IC Sc 12 Prop 8*6 or 7*4 It is one heck of a nice looking bird! Can't wait for the flight report! |
Last .15 pusher I built (OS .15 FP) I used Zinger 7-4's and they worked out quite well. IMHO 8-6 is way too much load for a typical .15 let alone a .12. Especially in a pusher configuration, the larger prop is going to encourage the engine to run hot on the ground, whereas the 7-4 as a lighter load should run cooler. MJD
Thanks for all the positive feed back.
I will post some plans once I have resolved a few issues with the design. The plane is a little heavy at the moment and needs to loose a few ounces. But will post a first flight report very soon (next week if the weather behaves its self this weekend). And as regards props ideally a 6*6 pusher would do but cant get the props...so will use the 7*4 at 16000 rpm which should give it a good 60-70 mph. |
1 Attachment(s)
Well first two flights not good...engine problems... to be presise engine feul delivey problem.
So back to work bench. Problem resolved with a thicker fuel pipe.....now engine runs very well so will solo this wekend and have not been idle have built the following other eletric versions and a ducted fan version is nearly complete with 700 Watts of power about 2.5 to 3 pounds of thrust. Here are a few pics |
After much ado about a launch... a will not be asking Jimbo to launch my planes again...he he but she fies managed two good flights but manged to go dead stick on last and stalled her at about ten feet and she nosed in but not to bad just a small repair to sides of the fuse where battery is located.
Need to test her more maybe a bit nose heavy so might adjust battery with repair and little engine screams on a 7*4 but looks good at 70 mph. Not the fastest but may try 8*6 which should make for a nice 100 mph. The SC 12 ABC runs like a demon and likes to rev at the top end... |
