RCU Forums - View Single Post - Thought about absorbers .
Old 09-13-2010, 07:26 PM
quarterscalelegends
quarterscalelegends's Avatar
Default RE: Thought about absorbers .
i dont think that would change it. the fluid would fill the bore and end result would be the same resistance as a small hole. I think it would need to be a 2 stage shock with 2 pistons. when the the shaft moves a certain distance then it starts to move the second one with smaller holes to increase the resistance. But of course this is backwards of what you want to do. You would want to decrease the piston resistance on compression since the springs resistance is increasing.
