RCU Forums - View Single Post - J1600R Over heat and shutdown !
Old 09-15-2010, 12:12 AM
ty_edge_540t
Default J1600R Over heat and shutdown !
Dear All,
I've just bought a new jet engine from PST. It is J1600R. When I started the engine, everything was fine and the temperature was about 560-600 degree C at the idle RPM (35.000 rpm). Then I started to power up, it was fine but at the top of RPM ( 120.000rpm) the engine became over heat and shutdown automatically at the 840 degree C. After that, I checked the temperature sensor and I made sure that it stayed correct position (about 5mm in the tail cone). I tried again but the engine was over heat again. Then I tried to pull the temperature sensor to 2mm in tail cone, unfortunately, the problem has not been solved. Would you please help me to solve this problem ?
Thanks All,
Eric Trinh
