Thread: gasser line
Old 09-15-2010, 07:32 PM
Charlie P.
Charlie P.'s Avatar
Default RE: gasser line
Note - if you have to buy gasoline with 10% ethanol like I am forced to do you may want to reconsider leaving the fuel in the tank. The alcohol attacks the rubber in the carb diaphragm pump and some fuel lines if left in contact with them. I drain AND run the carb dry after defueling.
