Thread: gasser line
Old 09-15-2010, 07:58 PM
Charlie P.
Charlie P.'s Avatar
Default RE: gasser line
This is from the manual of a gas 34cc engine I bought two months ago:
Use only low-octane, alcohol-free gasoline. The carburetor diaphragm will gradually deteriorate if you use gasoline with alcohol (ethanol, gasohol, etc.). You will need to replace the diaphragm in about 80 hours of operation if you use gasoline with alcohol.
This has a Walbro carb. All of my gasoline models use Walbro carbs. So I drain.
Your mileage may vary.
