RE: Typhoon static diving mini submarine
David -
Before you go spouting stuff as fact, you really should make sure that what you are saying is ACTUAL FACT.
"Later they where completly removed with very bad results"
The reality is somewhat different - Captain Davis - "We took the bow planes off the Albacore and our control problems went away."
"Also the Albacore had sail plains"
Not even close. Albacore had hull mounted planes ONLY, never sail.
I could debunk everything you've said using COLD, HARD FACT but my time is more valuable than that. My only concern is that you lead some newcomers down the garden (incorrect) path. If your way turns you on, fine. But PLEASE refrain from trying to jam it down everybody's throat.
Since what you've been pushing just flys in the face of reality, I suggest you give it up. Reality takes precedence over fantasy every time. Like I said, give it up. There's no way you'll be able to prove that bow planes are more effective/necessary than stern planes. Period. Let it lay.
Skip Asay
