Old 09-18-2010, 11:38 AM
HighPlains
Default RE: How to balance an airplane with a pod mounted engine above the wing
It sounds like it is balanced. But you can hang it by one wingtip with a string taped to the balance point and see if it is nose or tail heavy. Another method is to tie the nose and tail with a string and let the model hang from a single point with the airplane about level. From the same pivot point hang a plumb bob, and it will point to the balance point.
