RCU Forums - View Single Post - Hitec Aurora 9CH 2.4
Old 09-20-2010, 05:47 AM
A.T.
Default RE: Hitec Aurora 9CH 2.4
ORIGINAL: yak-54 hi to al
when changing to a lipo TX battery when do i have to change the program on the TX? beforereplacing the batteryor after plug in the new one (lipo)
thanks ilan
Either is AOK .
Aurora A9 - Lipo User Adjustable Voltage sets Shut Down = TURNS TX OFF to save damage to Lipo Battery and/or TX (Audible Battery Warning is still at 6.9V with Lipo which provides say 10-20 min before shutdown.)
Aurora A9 - Warning Alarms Battery types, voltage levels and consumption - with Power/Battery Management Screen Shots. CAUTION - Leave Auto Power Off as "Never" when using Lipo Battery. "Auto Power Off" is Hibernation Mode only (as with laptops). TX Does Not Switch Completely OFF and batteries will be completely drained if TX switch is not manually moved to the off position in good time. Will read as 'Auto Hibernation mode' from V1.06. As with all similar items, Hitec RCD recommend battery be removed and stored separately if TX is to be stored or unused for a period.
Aurora A9, Spectra Pro & Optima - FAQ & Undocumented Features - Mixes, Setups, Tips. {Individual Links often updated}
Regards
Alan T.
Alan's Hobby, Model & RC FAQ Web Links
