RCU Forums - View Single Post - G-62 lite
Thread: G-62 lite
Old 09-22-2010 | 08:54 PM
  #42
BadAzzMaxx
Default RE: G-62 lite
ORIGINAL: PlaneKrazee
ORIGINAL: BadAzzMaxx
Talking about getting criticized.
A little over two years ago I built a thrust stand that you could mount a plane in and test thrust with different props.
Was at a fly in and was having some fun with it, Tested a Area51 with a 23-A Vess prop and a DA with a 23-A Vess prop, The Area51 put out 2lbs more thrust than the DA at the same RPM
Had the video posted on U Tube but got so much slack about it I removed it.
We did the test three time to make sure nothing was wrong, So showing people thrust test does not seem mean squash .
Milton
Haven't you heard, DA engines are best no matter what. How unamerican of you to post real thrust figures that show the DA is not king.
That said, an industrial G-62 is an excellent motor, as is the Echo/BME 50cc chain saw engine. Both will last a thousand hours without problems if tuned properly and run smooth.
You should have never made that post, Here comes the blasters.
Milton
