Caster F8T with Baja 5T tires
I'm thinking about installing some Hpi Baja 5T tires on a Caster F8T. I'll be using 17 to 23mm adapters. How do you think it will look, what about run? I'm gonna put some 5000mah 25C 11.1v lipos on a castle 2200kv monster system. I've already reprogrammed the esc and turned the punch down. I need some weight. I need some tires that can handle 70mph. I'm also using a Savox 1267mg for steering so at 291oz that should be ok. I've got CVDs on all four wheels now. I've also ordered a jconcepts body. Any opinions or ideas on this idea?
