RE: HobbyKing OrangeRx Futaba FASST Compatible 8Ch 2.4Ghz Receiver
Yes they are the same.
My question is does it work with 7C? (i.e. the Futaba R608FS and R6008HS are "multi" while the 6 and 7 channels are normal mode).
The review in above compared it to the R608 but in fact it does support both FS and HS speeds. In fact, in some comments on other boards, it seems the default is HS which gives rise to youtube videos of people complaining their analog servos are getting HOT. Seems FS should be default but you can set for analog or digital which is more like R6008HS. However, Futaba says R6008HS is NOT compatible with 7C.
