RE: P-120 fuel line size
I do the same as mike with no problems.
You would think by now, pump and/or turbine manufacturers would fit a larger barb fitting on the inlet and a 4mm festo push fit on the outlet.
Likewise the valves should have 4mm festo fittings and not barb fittings designed for a soft pipe.[:@] Rant over!
