RE: Ram 750 setup problem
Many thanks for all the help. If I can will send video of test run. The turbine did indeed come with a separate oil tank. Has been T off from ECU. Using Exxon 2380 turbine oil I bought at local airport. So since turbine has it's own oil tank should I mix the oil with the fuel? Heard Ram made an uprated version that put out 20-22lbs of thrust. How do you tell what version that I have? Will resume sending pics of F-105F build soon so keep eyes out for it.
