RE: Solartex and Poly-Tak
I'd check with Chip Mull at F&M Enterprises. With Stits covering, the Poly-Tak is put down wet, in very small sections (10" or so), the covering laid on the wet surface, and then the covering is adhered by trying to get the Poly-Tak to come up through the weave with a dry brush. The Poly-Tak is also very thick so I thin it down with MEK to make it easier to work with. If it gets on top of the covering, Poly-Tak can leave some bumpy residue. Wiping those areas down with a rag lightly dampened with MEK will help smooth it out.
