RE: Everything Radial Engines
Southernx,
Have you installed baffles in the cowl to direct the cooling flow? Your air exits should be much larger (I think about 3-4 times as large) as your intake area. 18% total oil is fine with some castor to guard against a lean run. You don't want to cook the castor.
Bob
