RE: What to use.... Propeller question??
There was a small air gap between the engine and battery so heat was not a problem. Not sure if oil/fuel would bother it but he wrapped the pack in thin foam, then wrapped that with clear plastic tape to keep raw fuel and oil away from the batteries. I think he used a little dab of RTV silicone caulk to seal the hole where the wirewent through the firewall.
