RE: Engine Kills Chips?
You do need to do a range check, both with the engine off and running. Also of note, you are not supposed to change the frequency of your transmitter, that is supposed to be done at the factory only. You may also want to follow Edwin's advice, drop by and have him give you a hand. Good Luck, Dave
