Old 10-02-2010, 08:36 PM
Charlie P.
Charlie P.'s Avatar
Default RE: CA HINGE MATERIAL
Ooooo. I lose two points for reading incomprehension.
Irecess the to the pins. Digging out the slot with a hacksaw blade ground to a round edge on one end and a "V" cutter on the other, then the Nibbler to clear the slot. You can also swap a singlelength of 1/16" music wire along the whole hinge line instead of using the individual pins. Easier to pull out and seals the slot.
ID:	1510017   Click image for larger version
ID:	1510018   Click image for larger version
