RE: New TufFlight Bouncer - Build Thread
Next I attached the front reinforcements which strengthen the front end and support the glass rods for the motor mount. Using the template supplied I marked/drilled for the glass rods and attached the reinforcements to the top and bottom of the fuse with Gorilla Glue. I wanted to make sure I got even pressure while clamping so I made four plywood pieces covered in saran wrap.
Before applying all the clamps I checked to ensure the rods were aligned and had 2 degrees of right thrust.
