ORIGINAL: seravios
ORIGINAL: marquisvns
Rob:
You may want to try what Mark suggested, but if still intermittently fails to light up, look inside the front cover, you'll most likely see that one tiny metallic spot on the wire. This has been a problem for some of the older K80s, but not all. The repair is quite simple, or I could send you an upgrade kit and you can DYI. The upgrade kit is $90 plus shipping.
Good Luck,
Barry
can you elaborate about the tiny spot? Not really catch what you mean. THanks.
That's from the red glow wire underneath the multiplex connector rubbing against the casing, and the insulation or heat shrink wears out to expose a tiny spot of the actual wire or solder joint.
