RCU Forums - View Single Post - Covering with Solartex help.
Old 10-08-2010 | 11:52 AM
  #34
scale only 4 me's Avatar
scale only 4 me
My Feedback: (158)
Default RE: Covering with Solartex help.
ORIGINAL: TomCrump
ORIGINAL: scale only 4 me
ORIGINAL: DaveB
painting with primer and latex This will be a first for me and I would be appreciative of any comments regarding this method.
DaveB
Dave,
I have never used Latex over Solortex, but I will say this, All the times I painted over it I've use spray equipment, Sraying latex can be very difficult because of its thick nature, true for most water based products.. Also you want a paint that will go on thin and cover so the fabric weave is still visible, Other wise why used Solortex, right? I'd do some test samples to see what the finish product will look like before you commit to the whole model.
good luck
I agree with parts of this statement.
Latex is thick, and can be hard to spray. All waterbased paints are not viscous, or hard to spray.
Products from Nelson Hobby Specialties http://www.nelsonhobby.com/paint.html and Warbird Colors http://www.warbirdcolors.com/ are waterborne and very easy to spray. Both are fuel proof, and require no clear coat. Nelson's is available in flat or gloss. WBC is flat.
Tom,
Good point, "Waterborne" Paints/Lacquers/Ploy-Us are designed to be sprayed, and work fine,
By "Most" I meant the common house paints,, that's where you'll run into troubles
