Yah, dude, looks like you're running 9MM offset Meisters in the rear and 3MM offset TE 37's up front. Try to match them, either all TE37's or all Meisters.Go 6MM offset in the rear.
Raikou tires. You'll be pleasantly surprised how well they work. My advice? Get the combo pack, and an order of DXPE's. That will round out tires for just about any surface you will be likely to run on. That also means you will have to invest in more rim sets, which is cool, because if and when you get another drifter (they're like Lays potato chips, you can't have just one), you'll already have rim sets for that one, too!
