ORIGINAL: gokemidoro
Yah, I rushed the first GTR, it came out O.K., but it had imperfections in the plastic, so I got this body, and just took my time. The painting actually took only a day, but the masking took about 3.
You'll notice the wheels-3MM offset in front, 6MM in the rear. If the dimensions on your body are the same (and they look to be), you should end up w/ the same setup.
If you go Raikou, you'll have to lower your body a bit, so it looks right, because the Raikous are very low profile, and will make your wheel wells seem big, in comparison to the wheels.
Thanks for the advice! My next shell is going to be a 350z or a porsche though. First mod is gonna be aluminum driveshaft and softer springs
