RCU Forums - View Single Post - Canopy Latch
Thread: Canopy Latch
Old 10-13-2010 | 08:12 AM
da Rock
Default RE: Canopy Latch
ORIGINAL: wattmeter
ORIGINAL: Iron Dog
ORIGINAL: davidgeorge212
I have modified a few smaller planes that had canopys and hatch compartments with these little spring loaded latches. They work pretty good but I havent tried them on big models.
I've tried these on my YS .91-powered scale racing warbirds (such as in the P-39 pictured in my avatar), and unfortunately found that the vibration was too much for them. The hole that the latch mounted in would eventually enlarge enough that the canopy hatch would rattle and the paint would wear away from the continuous friction . . . all due to the vibration. I still found it necessary to bolt them down at the front of the hatch where the latch mechanism was located, So all the extra efforts of installing the latch ended up for naught.
Just a word of caution, for what it is worth. I wish you better luck.
Why not try putting a piece of brass tubing in the hole for the latch pin would go in?
wattmeter
Plastic tubing works well also. It stands vibration and you've got lots of it laying around, usually. Antenna tubes, pushrod surrounds, and such.
