RE: My DA50 Wont Start
Something else to check before calling DA.
1. make sure sparks are good and solid at the plug.
2. make sure the two carb screws are tight. Engine will not start if bad air leaks present.
3. make sure the engine gets normal amount of fuel. The engine should flood after 20 or so flip of prop.
