RCU Forums - View Single Post - Checking timing on a Saito 80
Old 10-29-2010, 09:45 AM
Xairflyer
Xairflyer's Avatar
Default Checking timing on a Saito 80
I have just redone the bearings on my Saito 80 and rebuilt it. Timing marks were lined up as they should but hard to know if it moved a tooth when dropping down the housing.
Anyway I can check the timing by say which valve is open/closed in relation to crank pin position or any method to confirm the timing is correct before I try to start it up.
