RCU Forums - View Single Post - compatible fail safe
Old 11-01-2010 | 10:18 AM
rchobbyunlimited's Avatar
rchobbyunlimited
Default RE: compatible fail safe
ORIGINAL: nitronut423
Hi I had the same problem then I found out the 2.4GHz dsm-2c radio that comes with the earthquake has a built in failsafe. Just turn both your transmitter and truck on then find the small black button next to the red LED light on the receiver. Apply full brakes, or your desired failsafe position and hold, then with a small screwdriver or hex wrench push the black button on the receiver and hold until the red light starts to blink {3-5 seconds}. Then release the button THEN the brake and it should be set. Test it by turning your truck and transmitter on applying full throttle {engine not running} then turn your trans. off and the failsafe should activate just like external failsafes.hope this helps
The only button on the dsm receiver that comes with it that you can push that is next to the led is the bind button that is used to bind or connect the reciver to the radio. When the led light blinks it is letting you know that it has been bind or connected to that receiver.
