at least they stopped using red lock tight..when I got my V1 there were random screws that had red loctite on them (some did but most had nothing)and i had to get the dremel out to a couple during my initial pre run strip down[X(]
you'll find 5B springs fit the shocks
, the ramtech 20% stiffer springs work well...the truck is heavy so benefits from heavier springs an oil.
make sure you pull the gauze out the exhaust can and lose that long stinger while you're running the can as it kills rpm and power
