RCU Forums - View Single Post - The "jitter "contnues
Old 11-04-2010, 08:59 AM
pacoflyer
My Feedback: (23)
Default RE: The
Thanks Mike for your reply...
The rudder is on a pull pull and the jitter does reduce a little when you remove the horns from the servos. This may be due to the fact that I have changed the deadband using one of your programers to 8 on each of the two sevos. We're gonna keep playing with the linkage to see if we can tweek it some more. Another thought was to switch out the DS 7 and install a Hitec Aurora and see if that works better. When the Futabab 2.4 was in there, the servos performed perfectly...
Thanks agian,
paul
