RE: Cleveland 84
I haven't posted since last week, because There is a lot of thinking to do here.
First, I have to figure out how to attach the wing to the body, since access will be important. The original, of course, did not have to worry about that, it was just glued on and done.
So what I have decided is to add a 1/32 plywood root rib between the wing panels, and have a tab at each end, to capture a horizontal nylon 6x32 bolt. In other words, the wing will be put on the body, then two transverse bolts willl hold it on. Here's a phot so you can get the idea.....
