RE: SuperTiger .45 HELP
None of you have talked about adjusting the mid-range. This is done if the engine does not transition well and is done by moving the inlet angle by lossening the two screws on the needle valve end and moving the whole assembly usually rotating the fuel inlet down.
L.
