RE: An Unofficial Rovan 30.5 Baja Terminator Review and Two Speed
Will....thanks for the review....been looking for one on this very truck.
Your review has really raised some major issues...making me very causious about buying this truck......
1. The clutch.....with that bearing faiure two times........Im a bearing engineer, and I can tell you that this bearing failed for one of two reasons.......a. radial preload causing excessive heat and bearing locking up....b. no lube in bearing which would result in same failure mode.......
2. The seller Danic.......sounds like a seller I should stay away from.....I mean he isnt even responding to you.........zero support....you might as well import the car yourself....if the seller is not supporting you........Just some guy trying to make a quick buck....but doesnt realize that everyone on RCU communicates to eachother...and its pretty easy to get a bad reputation with lack of support like that.........
Keep the upates comming....appreciate it.....
