RCU Forums - View Single Post - What do I do with this covering job?
Old 11-07-2010 | 11:21 PM
jester_s1
Moderator
Default RE: What do I do with this covering job?
To the OP- Your experience with the hair dryer should make it clear why we keep recommending a heat gun. As I said in my post above, the heat gun lets you put fast heat in just the right spot so you don't ruin your seams. You've probably used up all the shrink in your covering now, so what you have is as good as it will get.
