RE: 6mm paintballs?
Hello my flotationally challenged friend. I get mine from Toyeast. Get the Abrams guns as they seem to be the best performers due to their shorter barrels. They are cheap enough to get a few extras. They need a hopper installed above the gun but I think even the Monitor has enough headroom. I love those old ironclads.
Usually a misfire means you didn't load a bb or you have a jam. The issue with firing after a jam is that you are sure to break the bb's inside. Then the dripping starts......
Wish I could say they will work flawless every time but that's just not the case. Cruel fact is that reliable 6mm airsoft paintball guns in this package size just don't exist. Might just be that you have to pull up alongside with the Arizona and send it to the bottom for a thorough rinsing.
Perry
