ORIGINAL: smchale
Looks good Kirk. Interested to hear your thoughts on the s-bus system.
Thanks Sean. So far, I'm loving the S-Bus system. It so easy and simple to set up. You just plug a servo into the programming box, plug in the battery, turn the dail to the channel you want the servo to receive signals from, press a botton, wait for the light to quit flashing and the servo willrespond onlyto signals sent to the channel it is programmed to, chain the servos into an S-Bus cable and run the cable into the receiver. There is also a USB interface that allows you to use your computer toadjust end points, speed, etc. on the S-Bus servos. Here's the install diagram I made for the Texan showing how simple and clean the S-Bus system is.
Kirk
