Making more progress today. Did the nose wheel base. Pretty much the same as the main gear. I wanted to be able to unscrew the base and drop the nose gear out of the shuttle if I ever have servo problems.
I haven't screwed it in yet because I have to wire up the ESC (deans connectors to battery) and then hook up the reciever to then center the servo for the nose. You can see in the photo the servo/gear mount that will be mounted servo side up in the inside of the nose.
Steve
