RE: Skidoo Rev XP snowmobile hop-up
Snowmobile season is approaching once again.
I added some new suspension upgrades to try and help keep the track to the snow by replacing the cheap rear suspension shock (tension wire) with some oil filled shocks.
I'm presently experimenting with two versions of this.
The pictures show the cheap tension wire and the replacement system with a mono-shock and a duel shock setup. I tend to believe the mono shock is not stiff enough so I will probably go with the duel shock system.
